mikestock
Apr 14, 2015Explorer
Finally got the Whirlpool replacemant and got it installed.
Had to take a picture of the first 8 cube batch.
Will probably throw several batches away before harvesting ice because it has been inactive for some time.
Would advise anyone replacing a Norcold ice maker, wheather with this or a standard Norcold model, to locate the fill level adjustment screw and drill a small hole in the white rectangular cover to access the screw. There is no way to take this cover off, in case you need to adjust, without removing the ice maker.
To summarize: I replaced this with this.
