BFL13
Oct 15, 2013Explorer II
Ours is the Norcold 821 from 2002 or whenever (Trailer built Oct 02) and its door is not anything like that. So beware you get the right version if you swap parts.
Ours has a snap in rail only at the bottom, no tray, just the bottom of the door as a tray to hold those bigger jugs etc. The snap in rail goes in holes at each side with a ledge to keep it horizontal. You have a sort of ledge showing there, so a hole drilled and a replacement snap in rail for an 821 might do. Check out some 821s at an RV dealer to see the details/possibilities.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
