Old-Biscuit
Sep 11, 2020Explorer III
Stove has it's own LP Reg (Under stove top) --- set to hold 10"WC (0.36 psi)
LP Main Reg set to hold 11"WC *0.39 psi)
You can NOT tell the difference between correct LP Pressure and Low LP Pressure visually
Flow Limit Check Valve inside the GREEN ACME Nut. If tripped it limits propane flow if a leak occurs downstream OR if Service Valve/OPD is opened too quickly
To reset ---close Service valve then SLOWLY open it....no need to disconnect pigtail
