dougrainer wrote:
RVhiker wrote:
Yesterday, I noticed a problem with the romex that supplies the AC outlet in the refrigerator's outside access. A small loop of the romex was pressing slightly on a fairly sharp edge of a galvanized sheet metal brace that supports the sheet metal piece that the controls and etc of the refrigerator are mounted to. I looked at the romex, and there is a dark, sharp dent in the plastic outer jacket, maybe leaking current to the sheet metal bracket. I pulled the loop of romex away from the edge, wrapped the dent in electrical tape, and the AC refrigerator heating element is still working since then. I think that fixed the problem.
The link to the Norcold Service Manual is much appreciated.
Thanks to all for the electrical information and the willingness to help!
Thanks for the update. I MISSED where you stated HOW it tripped. A defective Heat element would NOT trip a GFCI unless the refer was turned ON to 120 power. Doug
It certainly could. The neutral side of the element is not switched and if it comes into contact with a grounded surface, the GFCI will trip even with the fridge turned off. This is no different than the neutral portion of the supply Romex touching ground.
GFCI's detect a difference between hot and neutral current OR a short between neutral and ground with no power flowing.
