JBarca
Jan 28, 2023Nomad II
Hi,
I am not up on the Norcolds, but I know the Domnetic well. They both work close to the same.
You may have a typo in your note. In blue, you say when the light over the sink is on, it makes the fault code, and the gas light stays on
And in red, you say if you turn the light "on" over the sink, the clicking noise goes away. Did you mean you turned the light "off," and the clicking went away?
You did not state if the LP gas was turned on and the air bled from the system. The fridge should have ignited the gas or gone into a gas fault after enough tries trying to light the fridge. Assuming the fridge is working right
If the fault code shows the electric element is faulty and you hear clicking, the clicking can be the gas igniter trying to work, not a relay. If you are in Auto and the 120 VAC at the fridge goes out, or if the controller thinks there is an electric element fault, or if you are in Gas mode, the igniter will start clicking.
As was said, you may have a 12-volt power supply at the fridge issue. It might be a ground issue at the fridge not allowing the 12 VDC negative not to make contact. OR do you have a local problem with the 12 VDC + supply to the fridge? Yes, the rest of the lights in the camper work, but that does not mean the fridge is getting a full 12 VDC supply.
Ideally, you have a volt meter and check the incoming 12-volt power at the fridge terminal block feeding the fridge. If you are plugged into shore power, and the converter is working, you should have 13.00. VDC or higher going into the fridge. (yes, 13.00 volts is correct, as 13.25 volts is float mode if your converter has a float feature, 13.65 is standard charge.) If you are on battery only, 12.7 VDC is all you will ever get 100% charged. If you have 12.1 volts, that 50% state of charge. Tenths of volts mean something,
If you do not have the 13.00 plus volts with the converter on, figure that out first. Also, look at all the ground wires on the fridge, if there is corrosion, clean it up.
The light over the sink may be on the same power feed to the fridge and when you turn. When that light is on, it can draw some power going to the fridge if there is a supply issue. . If the light inside the fridge blinks with each clock of the igniter, this points to the 12-volt supply power not being ample to run loads of the fridge.
I would not change a control board until you know for sure if more is working or not. You can test the electric element to be shorted out as that fault might be real.
The thermister has nothing to do with this at this point.
Hope this helps
John
seattler wrote:
Hi All! We are at home and plugged into house power. After a few months of normal use, the Norcold N611 refrigerator has started acting weird. It is not cooling. Additionally, no matter whether the fridge is set to Auto or Gas,
the fridge is affected by whether or not any of the coaches overhead light fixtures are turned on!!! If the light fixture over the sink is turned on, then the refrigerator panel shows the amber GAS light stays on, and the green ON light blinks 3 times every 3-4 seconds.
According to the manual, this is the fault code that indicates that the heating unit is faulty, and will need to be serviced/replaced. However, if I turn off all coach interior lights, the refrigerator behaves differently...the lights behave the same (same fault code), but in addition the unit makes a persistent clicking noise that I believe is the opening and closing of an electrical relay switch.
(And not to be confused with the overhead lights in the coach, but the interior light in the refrigerator blinks on an off with each click of the relay). Again, if I just turn on the light over the sink, that noise from the fridge goes away.
I already replaced the thermistor. I'm happy to also replace the control board for about $175, but I don't understand why the other lights in the coach would be affecting the refrigerator. Is there something weird with my 120V power supply? I have also heard that there might be a fuse on the circuit board that I could check.
Hope this helps
John
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
