enblethen
Jan 28, 2023Nomad
Your converter could be the problem. You need good 12-volts DC to refer. The converter or shore power is not providing proper power so the refer is cycling to propane.
Verify voltage to the refer with a good meter.
Try to listen for clicking while testing voltage. This needs to be done in outside access to refer.
It is possible that circuit for the refer is failing. I somewhat do not think it is failing.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
