dougrainer
Jan 30, 2023Nomad
Jeeez, ALL these posts and at no time, did someone suggest to check the 12 volts at the BACK of the refer. You need to check for 12 volts plus. ALSO, you need to check that your Power Converter is functioning. IF SO, your 12 volt system should show 12.9 to 13.5 volts. Also, ALWAYS post Year, Brand/Model of RV. Do you have Fluorescent interior lights in the RV. The ones that you can turn off and on to cause the refer to malfunction? IF SO, older RV's with Fluorescent lights had what is called AC ripple, from defective Ballasts in the light assbly's. Even tho the lights are 12 volt, defective ballasts can cause AC ripple in the DC system and cause appliances to act up. Respond with answers to these questions and the voltage readings I suggested. Doug
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
