dougrainer
Sep 27, 2018Nomad
luberhill wrote:
The freezer is below zero already so the thermistor should be good ??
WRONG! The Freezer has no bearing on the lower temp. You must put the refer on MAX(5), run for 24 hours and then sample a small cup of water that was left in it. The Thermister operates the lower section and a bad cooling unit will usually get to 0 to 10 degrees in the freezer. 24 hours running is the standard test time for RV refers. Let us know after 24 hours. Doug
PS, don't always believe what you read on the Internet(Moving the Thermister).
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
