luberhill
Sep 27, 2018Explorer
Old-Biscuit wrote:
Thermistor is on 10th fin because THAT is where is is suppose to be as determined by Norcold ----thermostat temp settings are based on that fin location !!!!
Enough of this 'moving' thermistor
Fridges that have temp setting adjustments the thermistor needs to be in OEM position
Fridges that have a PRESET thermostat setting ---those WITHOUT adjustable temp settings then moving the thermistor UP/DOWN....even side to side can make MINOR adjustments to overall temps
Freezer has to get to 10*F or lower BEFORE food compartment can cool effectively due to the 'cooling process'
Freezer FIRST in line of that process......food compartment LAST in line of that process
Turn fridge ON./electric or propane
Fridge reasonably level
WAIT 12 hrs or more for cooling process to occur.
Thermal Dynamics/Gravity Flow are a SLOW natural process vs forced circulation as in compressor units
Gotcha ! Just asking ....the freezer froze water solid in less than 2 hrs
I have a gallon of water and 6 beers in the fridge
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
