dougrainer
Sep 28, 2018Nomad
pnichols wrote:
We have a Norcold 611 in our 2005 motorhome and it still works great.
We usually leave it's cold switch to "3" on RV trips. This setting winds up over time of maintaining the refrigerator at around 37 degrees and the freezer around 10 degrees.
The recommended temperatures for refrigerators is 0 degrees for the freezer section and 38 degrees for the refrigerator section.
For us, a 10 degree freezer keeps ice cream perfect. A 0 degree freezer keeps ice cream too hard for immediate enjoyment ... which is exactly what happens in our home refrigerator that precisely maintains 0 and 38 degrees in it's two sections.
I'm not at all sure that a higher switch setting "speeds up" the cooling process. It makes most sense to me that a higher switch setting only changes the target temperatures that you want the unit to hit and stay at.
Setting a lower temp setting does not get the refer colder faster. Same thing (my wife argues this), setting your home AC tstat at 65 instead of 70 will get it colder faster. Not true. Unless you have a newer variable speed AC system. Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
