pnichols
Sep 28, 2018Explorer II
dougrainer wrote:
Setting a lower temp setting does not get the refer colder faster. Same thing (my wife argues this), setting your home AC tstat at 65 instead of 70 will get it colder faster. Not true. Unless you have a newer variable speed AC system. Doug
Just a couple comments to the above:
Setting our sedan's AC tstat to a lower temperature does "feel like" it's cooling the car interior faster - cuz the A/C's circulation fan runs at a faster initial speed if the AC is set to a lower temperature when first getting into a hot car.
FWIW, our home's heat pump system does cool the home faster when we set it to cooler setting because both the variable speed circulation fan and variable speed Scroll compressor run at a higher speeds.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
