barnaclepete1
May 22, 2015Explorer
Old-Biscuit wrote:
Have you rechecked freezer/food section temps....are they still increasing on propane?
Yes, I put it on AC and temp drops to 32 in fridge within an hour from 45, switch to LP and it goes to 45 within a couple hours.
I called a local norcold auth repair shop and he said it sounds like potentially spider webs in burner tube and the flame can still "look good" but not provide sufficient heat. that's the only thing that makes sense as the fridge worked fine for 6 trips before this. wouldn't that mean baffle and other things would be fine (unless they somehow fell but that seems unlikely)? If nothing else at least this guy is willing to try and sounds like he knows what he is talking about. The service rep at dealer clearly doesn't care, he recommended taking it somewhere else but it is under jayco warranty for another 1.5 years. pretty awesome.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
