dougrainer
May 23, 2015Nomad
Wishbone51 wrote:
I had a similar issue, where it would work perfect on AC but not at all on LP. The dealer said that the cooling unit needed to be replaced. I was skeptical, because it worked fine on AC, but it was replaced under warranty (aftermarket), so I didn't complain.
They replaced a GOOD cooling unit. A cooling unit does NOT CARE what the Heat source is to cool. If your dealer replaced for no cool on LP but cooled on 120, your concern about who cares it was under warranty, just means what are they going to misdiagnosis and charge you for after the warranty is up. Replacing the Cooling Unit in this case would have been $1000 plus mistake if not under warranty. I would NOT trust that Dealer to work on my RV. Doug
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
