j-d
May 09, 2017Explorer II
Shelborne wrote:
I am plugged the thermistor like I did before, and for some reason it may be cooling now. It's really hard to say at this point, I'm going to leave it for three hours or so and check back tonight.
Thermistor calls for more cooling the warmer it gets, increasing its ohms resistance. If it fails "open" or is unplugged, the logic board tells the cooling unit to run. If it fails "shorted" or the wires are pinched into a short, then the board tells cooling unit NOT to run.
At least that's what I learned about Dometic, and I believe Norcold uses the same concept.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
