dougrainer
Aug 25, 2020Nomad
On 120 volt, you will not get this error. The red indicates FLAME out error. So, as long as the burner and areas are clean, YES, make an appt with your dealer. Norcold has had issues with the rear control board for the past 2 years. Replacement is required after a Service Center does its checkout. Doug
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
