agesilaus's avatar
agesilaus
Explorer III
Oct 06, 2020
Norcold N811 fridge-no power
OK we have a Norcold N811 and it was working fine a few weeks ago. We powered it fdown when we got home. When I tried to power it up again to get ready for another trip the display is blank and it does not respond to the on/off switch.
1) 12V Fuse is OK
2) Checked 120V outlet that the fridge is plugged into with an outlet tester and it is fine.
3) Propane is OK, runs stove burners and oven OK
so this seems to come down to the circuit/power board.
I don't know where the power board is tho, is it inside this black box in the outside access hatch?
Also how can you get to the on/off switch, there doesn't seem to be any way to open the panel. Do you have to pull the fridge out from the wall?
Thanks for any help or suggestions.
  • OK how do I check that switch? I see something with wires running to it inserted in the flue, so I assume that's it. Do I just short it out?
    I got 12V at the circuit board BTW. And when I was cleaning up the compartment I found a circuit diagram on the bottom of the compartment. Unreadable since it is under all sorts of flue piping.
  • OK by flashlight, I pulled the wires from that round device in the bottom side of the flue. I fridge did not respond to the off/on switch with the wires disconnected or with them shorted out. I see from the drawing all the way at top that there is another device above that switch. A thermister? Do I need to check that and how?
    If these are not the problem what is left? The circuit board has 12V and the two fuses check out with an ohmmeter. Amazon has a replacement board, should I order one or call the mobile RV guy. I tried the guy we used last time, he is not taking work until after Christmas. But there are a couple of others in the area.
    The replacement board is $128 and the rv guys are $100/hr including travel time so the cost is about the same.
  • OK just an update.
    OK the only thing left seems to be the eyebrow panel on the front of the fridge. A trip to YouTube showed me how to get to it. I opened it up and it was quite dirty. I gave it a clean up with contact cleaner. Still does not work tho.
    Thinking back on this, I have not been able to set the temp on the fridge, I could cycle thru only some of the temp settings but no matter where I set it, it would revert to setting: 5. Maybe that was an early sign of trouble.
    So I suspect either that board or the membrane switches which I don't see a way to get to so far. There is only a ribbon cable and I don't see any obvious test points.
    Any suggestions?
  • Gjac's avatar
    Gjac
    Explorer III
    Another thing to try is the other end of that eyebrow ribbon where it attaches to the control board. When mine would not work on electric I removed that harness connector and cleaned the contacts with a pencil eraser and reconnected the harness and all was well again. If that does not help I would remove the control board and look at the back side and see if you see any burned tracks in the solder tracks if so it might be the control board.
  • Gjac's avatar
    Gjac
    Explorer III
    How are you making out with your refer problem?
