azbohunter
Aug 12, 2018Explorer
Norcold N821 not cooling
My unit (Norcold N 821) is original equipment (2002) and we spend 5-6 months a year in our 5th wheel.
With coldest setting we are seeing temps in low 40's. Doesn't matter if it is on gas or electric.
I have bypassed the control board and wired the electric element direct and left it over night and it got down to 30.4 with outside temp in mid 60's. I have removed the cover off the roof and there is no blockage.
If I am correct, by bypassing the control board I have eliminated that as the problem?
I am now assuming that it must be the cooling component so then options would be a new refer or replacing the cooling system. Both require pulling the refer out.
We are in a State Park in Oregon and will be here for two weeks so I can order parts and make repairs.
Question is: Is there something else that I could/should check? (am I missing anything?) I should add that the 30.4 is with 2- 1/2 gallon milk bottles of ice in refer over night and I have tried both gas and electric with same results.
A rebuilt cooling unit is $500-$600, a new refer is pushing $2000. I am leaning towards repairing, what are the thoughts of those with more knowledge than myself.
