sullivanclan's avatar
sullivanclan
Norcold Questions/Not Cooling
I have a Norcold model N821, probably a 2003 unit that will not cool on gas or electric. (Cools some if the temp gauge is moved all the way to cold). From my research thus far, when both do not work it is most likely the blocked tubes. A few questions as I move ahead:
1) Has many of you changed out your own fridges instead of having a RV shop do it? My thought was to have the RV shop do the diagnosis and then I could change it out (if it is shot). (Since they have seen a lot of fridges they know more about the diagnostic parts)
2) Is getting about 15 years out of a RV fridge pretty good? Seems to me it is as I have friends changing them out at less than 10. I know it has to do with a lot of different variables.
3) Any big difference in a Norcold versus a Dometic when it comes to replacing them? Quality/longevity? Anybody purchased one, or had a shop do it and knows the costs?
4) Rebuild, versus replacement? By the time to you remove, repair/rebuild, parts and labor your almost into new?
Thanks for any suggestions....
  • Mine is a 2002, and it still works perfectly; very cold in fridge and freezer when set on #7. According to Norcold it is not in the group that have been recalled, BUT, I am replacing it anyway, with a residential unit, when the one I just ordered today, is delivered.
    If you were closer...
    If handy and can follow instructions.....DIY
    Best to have help pulling fridge out/installing back in.
    Few hours to R/R cooling unit
    15 yrs reasonable
    Some go longer, some only few years
    Depends on number/length of time operated 'off-level' (damage is accumulative/permanent)
    SAME
    Cooling Unit----$600
    New N821-------$1200
    New 'residential' fridge....cost of fridge plus battery upgrade, inverter circuit, solar/generator etc.
    To 'test' if cooling unit is bad
    Unplug electric element leads from control board
    Plug leads directly into 120V AC outlet
    Run fridge for 24 hrs wired directly.
    If cooling unit is working.....then freezer will get to 0*F/food compartment will get to 30s*F cause cooling will be continuously.
    IF it is cooling then thermistor is probably bad or circuit board has failed
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
