edatlanta
Oct 08, 2016Explorer II
Per Norcold, all of their units go through a cooling unit defrost cycle every 46 hours (or was it 47?). This is NOT a freezer frost defrost, but a defrost cycle for the cooling unit. It is perfectly normal operation and you can not change it. This is exactly what you seem to be describing. If you just leave your thermostat where you had it at 6, which is what I use on mine, it will work fine, just with the temp increase/decrease every 46 hours.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
