mwhich's avatar
mwhich
Norcold Refer
Hi to all, My 2111 series norcold continues to power off, propane does not kick on unless I literally go outside, open the access door and unplug the 120V power. Otherwise it just turns off, power lite is off etc.... Any help? Thank you in advance. Recall has been performed.
1 Reply
  • Lots and lots of threads on NearColds, NeverColds, NorColds. Do a search. With such little information it sounds like a control board issue. As you will find after you do some research. The bottom line is you will have to replace with an Amish cooling unit or residential model. Alternative is years of frustration and problems.
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 19, 2026
