Spade_Cooley's avatar
Spade_Cooley
Norcold Refrigerator problem
I'm in a park on power, 30amp in a travel trailer. I opened the door to the unit and the inside light goes out. I shut the door and the green power light flashes twice over and over. I looked at a guide and it says power or fan problem. I have no idea where the fan is or if I even have one. I never heard it run. I will call the repair service in the morning and for now I switched over to gas.
  • When it's off you need to check the power to the control board, 12 VDC and 120 VAC. What does it show on the inside display when it's off? This sounds like maybe a loose connection. Check all the wiring going to the board. One of the push-on connectors could be loose. Does it have the Norcold recall box?
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
