- brulazExplorerDecided to order the 100A version. That should cover my 1000W inverter and other DC loads.
But any issue with putting the shunt on the ground line from the batteries to the frame? The batteries are mounted on the tongue in little plastic boxes, and the positive terminal is pretty congested with the fuses. I do want the meter to measure net Ah, from both loads and charge sources. And I do have a separate battery voltage display at the solar controller, so don't need that. - rjsurferExplorerHow far from the shunt and case can I put the digital readout?
Ron w - MrWizardModeratori like this one 250amp capacity
http://www.ebay.com/itm/DC-120V-250A-Volt-Amp-Combo-Meter-Battery-Charge-Discharge-Remaining-Capacity-/171052067910?hash=item27d37f6c46
i would need this one, i would fry the one in the other link, either charging or using my inverter
thanks for the link, i was able to find this one in his store - Harvey51ExplorerAnd the 90 amp Chinese "trimetric" for $29. Ebay
I have the 25 amp version, which has worked perfectly for a couple of years now. It is a full battery monitor that detects all current going in and out so it can calculate and display the state of charge accurately all the time. In per cent of full charge or amp-hours.
The thing is, a voltmeter provides a very inaccurate estimate of the per cent of a full charge and that only 8 hours after all charging has stopped. A current meter tells you how much draw there is now but gives no indication of how charged the battery is. Better to get the Chinese battery monitor for $29.
Another thread like this one: RV.net - Boon_DockerExplorer III
CapnCampn wrote:
I was eyeballing this one: Meter
50A (others available), says it will do forward & reverse, also shows Ah.
Was concerned about display brightness though.
CC
Display is very bright and can also be turned off if you like. - Boon_DockerExplorer III
bbaker2001 wrote:
how do I tell if it comes with the shunt, I would like to order one
Look for "Auction includes" in the ad below "Product Description", states that it includes a shunt. - bbaker2001Explorerhow do I tell if it comes with the shunt, I would like to order one
- SCVJeffExplorerNice...
Those LED's will be plenty bright - MEXICOWANDERERExplorerAnd forfeit any data...
Having RV issues? Connect with others who have been in your shoes.24,335 PostsLatest Activity: Nov 14, 2025
