gotsmart
Jul 18, 2013Explorer
MEXICOWANDERER wrote:
Boats, bilges, floats, batteries
Might be a coincidence... :)
X3. I know folks who use a marine pump on a battery set up that is connected to a trickle charger. Battery and charger are mounted well above the high-water line.
It is set up in addition to a sump pump and it's float is set to a slightly higher water level than the sump pump's float - so that it does not turn on until the sump pump loses power.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
