time2roll
Jul 19, 2013Nomad
Your bilge rating should be rated close to the regular pump. Watch the volume at the correct head pressure. You can use the same outflow but it will need a check valve.
Lifeline is an AGM battery. http://www.lifelinebatteries.com/marineflyer.php?id=2
Not exactly low cost. Should serve 8 to 12 years.
I would get a marine charger about 5 to 10 amps. Get a permanent mount or onboard syle.
http://www.batterystuff.com/battery-chargers/12-volt/5-10amps/
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
