steve23's avatar
steve23
Not an RV question - Backup power for a sump pump
Hi,
This is not a RV specific question, but I thought this would be a good place to start.
Every year in the summer, we always worry about the storms that pass through and the resulting flooding that can occur in our basement if the power goes out. It has happened.
I’ve considered gas powered generators, department store bought battery power backup sumps, etc.
But I recently read something that suggested a deep cycle battery could provide enough power to operate a standard pedestal sump pump for small length of time. Now I’m not taking about a heavy duty sump pump that needs to lift water high, just an average sump pump that pushes water about 4 feet high, maximum. Although I haven’t read the amperage on our existing pump, I’ve seen a 1/3 horse pedestal with an amperage less than 4 amps.
All that said, I’ve come up with a scenario that I think might work. But not knowing much about chargers and inverters, I thought I’d post it here to see what others thought.
My plan is this...
1) Two 12v deep cycle batteries wired in parallel. Positive to positive, negative to negative.
2) On one side of the battery "bank", I attach a 12v battery charger that keeps these two batteries charged.
3) On the other side of the battery "bank", I have an inverter that inverts the DC to AC to provide power to a pedestal sump pump.
4) Inside the sump hole, I have the original AC powered sump, set lower to work when the power is on.
5) Also inside the sump hole, I have a second sump pump which will be my DC pump should the AC power go off. And of course, the DC pump is set higher and will only turn on when the water level increases above the AC pump's setting.
The above would satisfy two requirements,...
1) Provide a backup sump pump should the power go off.
2) Provide a backup sump pump should the original AC pump die.
*** The most important requirement that it satisfies, is that it provides a backup when we're not home to fire up a gas generator.
What do you think? Does this plan make sense? Any suggestions on power requirements or brand names for the batteries, charger and\or inverter?
For the devices (batteries, charger, inverter), I'd be looking for long manufacturer's warranties.
Any help or advice you can offer is greatly appreciated.
Steve.
  • As another idea to help with things, I wonder if it would be possible to toss some solar panels on the roof, as well as go with some larger 6 volt solar batteries.
    The size of both can vary, but I'd probably get enough panels to completely charge the batteries in one day (around eight hours), then have enough battery amp-hours to run the sump pump for at least 4-7 days. That way, the panels will always be ahead of the pump's energy use, even in bad weather. To boot, add an AC charger so if there is mains power, the batteries will always be topped off.
    What this will provide is a "guaranteed" 4-7 days of sump pump usage if power goes out, then if the solar cells are done right, the battery powered sump pump could run indefinitely off the panels.
    If snow is an issue, the panels can be faced at 35 degrees or steeper which would help it fall off, and there are places which sell heat tape to help with keeping the panels clear.
  • I have been looking at the same set of questions you are asking for some time. My sump pump runs on average every half hour (underground springs) so if the power were to go out or pump failure I would have a wet basement.
    I have come down to this, a $5.00 alarm if the water reaches the floor. Know its only good if I am home. I then added sump pump failure insurance to my policy. I figured if power went out it would be for a short time, thus no need for back-up. If pump goes out guess i will return to wet basement.
    If I really wanted protection I would invest in the generator that will start when and if the power goes off. This would cover all aspects of the house.
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 12, 2025
