enskpo's avatar
enskpo
Not enough space for lugs on post of battery isolator
I'm replacing the cole hersee battery isolating solenoid because it's been working intermittently. The replacement is the exact part except the studs are about 1/8 shorter, and I can't fit all three of the lugs on the stud with room enough to screw the nut on top of them to hold them down.
I'm thinking I need to buy a heavy duty bus bar in order to get these connected, but I don't know what size. Since the starter battery delivers 975 cca do I need a $130 1000 amp bus bar? Or am I going down the wrong track?
  • BFL13 wrote:
    What I would do is just get a short #1AWG and bolt (really tight!)all four lugs together, then put the #1's other lug on the solenoid. Wrap the bolt and four lugs in tape for insulation.
    Of course everyone will be appalled and want you to spend the $130 :)
    Great recommendation. I have done this and it works great but over time encountered a bit of corrosion where the wires are grouped together. Still a good solution.
  • Another option is to get a short length of copper water pipe, flatten it in a vice, and drill suitably.
    The bus bar or whatever simply needs to be sufficient for the current flowing through it, not for the theoretical rating of the starting battery. At least in my RV that would be determined by the master fuses at either end of the solenoid, or something like 175A if I recall. Failing that, the wire sizes give some clues as to what to expect.
    Not at all, Macgyver. That's simple and brilliant. :C
  • What I would do is just get a short #1AWG and bolt (really tight!)all four lugs together, then put the #1's other lug on the solenoid. Wrap the bolt and four lugs in tape for insulation.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 22, 2025
