wolfe10
Aug 18, 2013Explorer
Is your EMS between CG outlet and the ATS (Automatic Transfer Switch). If so, and EMS recognizes proper power you have a problem between there and the main breaker box. ATS is where I would start looking Points could be stuck in generator position.
If you are not safe working around 240 VAC, I would suggest all you do is tap lightly on the outside of the ATS-- sometimes that is enough to free the stuck points (temporary fix). If you are safe working with 240 VAC, take the lid off the ATS and check for power in and out while on shore power.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
