JamesBr
Aug 19, 2013Explorer
When you plug in you should hear the ATS click over to shore power. In the past when my transfer switch had issues it just did not power up at all. I have a 2001 Monaco Knight and its the intellec EMS installed. When I am on 50A shore, I do not get a readout on the amperage draw, that only works when on genset or below 50 amps shore connection. And per the documentation I have that is correct.
The EMS usually is not set to shed the converter/inverter, so you should have power on all of those outlets. Do you have power anywhere like the microwave, non inverter outlets? Or is the entire coach offline even with the EMS showing you have power?
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
