Old-Biscuit
Jan 05, 2017Explorer III
Suburban uses a very simple circuit for electric and for propane
AC/DC Junction boxes are on backside of WH.....one each side
Electric..
120V AC from Main Power panel via a Circuit Breaker
From CB to On/OFF Switch
From On/Off Switch to t-stats (Left set)
(High Temp then via connector wire to Normal temp----HI has 'manual reset push button)
From t-stats to element (black wire) then to Neutral (white wire)
Follow the 120V AC VOLTAGE ---find where you loose it
Propane.......
12V DC from Dist Panel via FUSED circuit
TO On/Off Switch to t-stats (Right set) SAME as 120V Hi/normal
From t-stats to Circuit Board (rear corner of tank)
From Circuit Board to GAS valve (Brown wire---then to ground) and to SPARK Electrode (Heavy Orange wire)
Spark electrode fires igniting propane
Propane flame then 'ENGULFS' spark electrode generating a signal that goes back to circuit board 'PROVING' main flame lit (no signal...shutsdown)
Electrode is firing/main flame lites
so Check electrode position (engulfed in flame)
Check electrode CLEAN (no sooting/carbon...otherwise no signal)
Check spark electrode ground (assembly mounting screw...clean/tight connection)
Check electrode ceramic ....no carbon/cracks otherwise signal will track to ground
Check that electrode high voltage wire connection is clean/tight
Also check that both High Temp T-stats are not tripped.Push button in to reset
Electric..
Propane.......
