DD716TED
Feb 19, 2017Explorer
westend wrote:
I'd bet that you're not going to be able to completely draw that metal straight with a bolt of any kind. It appears that the bracket is made from 1/4" steel and has had a large force on it to bend it (driven away with a jack still down?). Since I have a welder and a bench vise, the cure is simple, cut off the welds with a grinder, straighten in the vise, and weld back down to the frame.
You may wish to seek the aid of a welder with this because it is n easy repair. A torch applying heat, a hammer blow or two, and then two additional welds would put it right in minutes.
Somehow the picture is misleading. The thickness of the bracket is 1/8" or less. I can / have used a c-clamp to bend it back up flat against the frame but keeping it there is why I asked about using a bolt on each side. If not, I will grind the welds off, use a new bracket that came with the replacement jack and take it to a welder (my son).. Just didn't want to haul the trailer from storage to do it if possible.. thanks for thoughts
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
