j-d
Sep 06, 2014Explorer II
OBD-2 Reader Not Reporting Data
One of these little joobers
This one's from Amazon, apparently there are several, based on a chip called "ELM327" and supposed to "support all OBD-2 protocols" and run under Android on a Smart Phone.
My Motorola Droid Ultra shows it's Paired in Bluetooth with "OBD2" and the recommended "Torque" OBD-2 app shows the Device. Just doesn't display the Code (probably O2 Sensor Heater) that has the Check Engine Light lit on our 1997 Ford Aerostar. It also does not display any other info like "Engine RPM" that have to be happening if the vehicle is running. Torque display is "No Data From Device."
Suggestions?
Other than "Don't miss the Amazon Return-By-Date?"
THANKS!!!
Suggestions?
THANKS!!!
