dougrainer
Apr 01, 2018Nomad
The FINS which are very close to the top rack will be 10 degrees COLDER than the actual temp. So, put that cup of water in there and test the water. If you have a CU that works sometimes and does NOT, then you have a partial blockage. Your unit is 11 years old and you have no clue as to what the previous owner did with that RV. The fact you changed the tstat to an adjustable one will NOT make the refer run colder than it is capable of. What type of Thermometer are you using. A Dial round thermometer? A Digital Thermometer? OR a CHEAP generic refer thermometer? If the round Dial thermometer---CALIBRATE it. You put it in a glass of ICE water and then turn the dial to 32 degrees. Doug
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
