Old-Biscuit
Apr 03, 2018Explorer III
dougrainer wrote:Old-Biscuit wrote:drsteve wrote:dougrainer wrote:
I would say your after market Thermister system is the culprit. Since your test show a fully functional CU, the only thing that is a variable is a NON Dometic part---The aftermarket Thermister. THAT controls when and how the Refer cools. There are NO moving parts in the Cooling unit, all it takes is Gravity(being level) and HEAT to function. Doug
The OP stated that the problem was there before he installed the aftermarket thermistor. I'm still trying to figure out how the freezer hits -24F.
Yep...
OP changed the thermistor to a rheostat replacement because CU wasn't cooling...then it was cooling...then it wasn't ....then it is again
Cooling unit is DYING
A dying CU will not perform as the OP's. When it works, it works TOO GOOD, for a marginal or bad CU. Doug
TOO GOOD......exactly
When have you ever measured -24*F in a freezer even when being 'forced cooled'?
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
