GATJcampers's avatar
GATJcampers
oil in air filter for generator
I was camping in the desert with my generator (onan microquiet 4000 with 224 hours)when it suddenly died. I have a toyhauler and it was about 90 degrees and it wasn't under a large load. So i opened the compartment everything appeared to be fine. I figured I would check the air filter, so I cracked the filter housing wing nut and bam out pours some oil.? all told about 1/4 to 1/2 cup came out. the filter had oil on it, not a lot but some. cleaned it all up and it ran fine. Why was there so much oil in the filter housing? any ideas? There is a breather tube from the valve cover to the air filter housing but is it supposed to put that much oil out? any ideas? Thanks in advance
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
