wa8yxm
Nov 11, 2023Explorer III
StirCrazy wrote:
looks like your converter is fried. should be 13.6 to 13.7 with no battery hooked up. so, you likely need a new converter and a new battery
I'd need to haul some serious test gear into his rig to make an "Diagnosis" but.
13.6 volts DC is not the same as 13.6 RMS.
The old Magnetek 6300 Well if you read on the older analog volt meters the DC out was like 12-12.6 but if you read on the type of hardware I have you saw 18 volts (Depending on the device. I have both kinds)
so his 12 volts... might just be poor filtering of a supply with lots of ripple. Or it may be a very smart converter that says "Well I do not sense a battery so I'll go with the lower voltage"
Some I'm told do that. never seen one but that's not the business i'm in.
But if you are planning on running w/o battery by all means.
If it's a trailer you need to tow.. Use a battery tender on the disconnected battery. re-connect to tow
Or upgrade converter to a Progressive Dynamics 9200 series. (or 4600 if it's part of the power distribuition assembly).
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
