dougrainer
Aug 26, 2016Nomad
KendallP wrote:
Doug,
How do I hotwire/bypass tthatswitch to test?
GOOD question. I think there are 6 wires to the switch. Maybe 5. I no longer have a schematic for that 30 year old refer. GOOD news is, you can connect all together as all it does is jump power to the board and the Hi humidity Heater strip. Find the HOT 12 volt wire. Then take each of the other wires one at a time and connect to the 12 volt wire. When you find the one that activates the eyebrow panel jut jump those 2 together. I would not worry bout trying to activate the Hi Humidity heat strip. Doug
