dougrainer
Aug 27, 2016Nomad
There is no ground, or there is no positive. I never had to check. BUT, there will not be BOTH. You NEVER need Pos and Neg thru this type switch. You are only routing the wires together. That is why I stated, connect all at the same time and the Eyebrow may light up. IF NOT, then the rear board is bad. Doug
