TeetonExplorerJan 13, 2017Old tv to new tv with old flat wireI have a old 1983 motorhome that has a old tv antenna that has a flat wire that has 2 wires inside. The antenna that you screw up works well, but I got a new flat screen tv and it only has a place for...Show More
agesilausExplorer IIIJan 13, 2017That flat wire cable is actually called 300 ohm cable, you want an adapter to coax: amazonYou will need a short piece of 75 ohm coax cable to go between the adapter and the TV
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
Related ContentAdding power outlets in slide with no wiringFleetwood Angler wiring2005 SixPac D850 WiringBad tail light wiringFlat
