Buffblazer
Jul 01, 2019Explorer
I replaced the regulator last year when I purchased the camper, for being as cheap as they are I can do it again just to be safe.
When I left this morning the fridge was at 55, I left the fans running and when I got home it was 80 in the fridge. Flame was still there and fans running with outside temp around 85.
So I took everything apart again and cleaned it. Ran gas through the open line to make sure that it wasn’t plugged and reached up in the flue and cleaned what I can. Letting it cool down now.
I found the model number and was look at what is says to do to service. Looks like I have to take the fridge out to clean the chimney? Anyone else cleaned that out before?
Also on the burner. I have the main gas line coming in, then the little slot for the electronic ignition, and then on the other side is what looks like a brown probe. It runs from the burner back to the gas valve next to the switches. It doesn’t look like a gas line but does connect to where all the lines are.
Anyone have any idea what I’m talking about? Not the best with describing it.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
