dougrainer
Jul 02, 2019Nomad
Buffblazer wrote:
Ok that makes sense. It was loose so I was wondering if it’s depth in and out of the burner mattered.
So I cleaned everything again, turned on the gas without anything attached to push any debris out of the line and reached up in the chimney and cleaned what I could.
Turned it on with the fans at 7:00 at a fridge temp of 80 and at 9:00 it was 55 ( I know I shouldn’t have opened it but I was curious) I shut off the fans and this morning it was at 25 degree. So that made me super happy. I kicked on the fans and will check it again tonight after a 85 degree day.
So, with NO fans, the refer got down to 25 degrees? If so, WHY would you operate the Fans? Remember, the point of refer convection is to flow air thru the Condensor fins, REMOVE the heat and flow out the upper vent. IF you force the air thru those fins TOO FAST, they will not remove the heat. So, maybe you have to fast air flow. Doug
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
