JRscooby
Jul 05, 2019Explorer II
dougrainer wrote:
The ONLY way to test LP pressure is with a Manometer. Buying one for $60 is cheaper than paying your Local RV dealer to do a Manometer check
But AFAIK, no mater what you pay for a Manometer you must make a gas tight seal to the line. I used a clear plastic line that fit tight on the flare. Left the line long, tied up to top of lower opening, (above the valve) drop down, ran across ground a couple feet, then loosely zip tied to a yardstick. Put enough water in the tube to fill it for a couple of feet. Hold the stick verticale, and slide it until water level is on a mark, and tighten the ties so it stays put. Turn on the gas, if the water line goes up 11.5 inches, your good.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
