ernie1
Jul 07, 2019Explorer II
dougrainer: Neither of my friends nor I have slides in our rvs and since we have identical problems common to two different models of new Dometic fridge in that the fridges work fine on ac but poorly on propane I'm certain that the issue is propane related and less an improper installation. Question is, what to look for that the rv repair shops in conjunction with Dometic techs can't resolve. I think Dometic has flaked on this issue. My thinking is either an undersized gas jet, a crimp or restriction somewhere in the gas supply system (which might be a Dometic design issue). Gonna check the gas supply pressure and, if less than 11.5, adjust the regulator accordingly. Can't get any info on the proper jet size nor availability because Dometic says they can't give that info out nor can they give any references probably due to a liability issue. So Doug, what do you think?
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
