NRALIFR
Jul 10, 2019Explorer
Yes, the LP pressure is too low. It should be adjusted to maintain 11.5” with most of the LP appliances going. In fact, I would try to adjust it for 11.5” with the furnace, water heater, and generator going. If it won’t adjust, you’ll need to replace the regulator.
Your regulator should be sized by the total btu’s of the LP appliances it’s supplying gas to.
Here’s a link to a topic of mine that is very similar to this one. You might find it helpful.
LP System Questions Topic
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
