laknox's avatar
laknox
Nomad
Aug 09, 2023
Older Norcold fridge issue
The fridge in daughter and son-in-law's '98 Nash TT is on the fritz after working well just a couple months ago. Freezer is 4 degrees, but the fridge is in the 50's on both AC and gas. No ice buildup between top and bottom to impede airflow. We pulled the vent cap off and the coils look reasonably clean. Plenty of hot air up through the vent, though we didn't check the flue itself. We pulled the box around the burner and cleaned out some dirt and junk from there, but it wasn't affecting the flame. We used some canned air to blow off what we could around the burner.
All that said, should he bite the bullet and put in a new fridge or would one of the "Amish" replacement cooling units be a better choice. Almost double the cost for a new fridge. Are newer units better? How hard is it to swap out the cooling unit as a DIY project?
Thanks,
Lyle
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
