ken56's avatar
ken56
Omni directional antenna
OK folks, I, like others have had crappy reception from my antenna so I finally got up on the roof and took a closer look. There is a small red(18ga?) wire next to the coax that is cut and not connected to anything. Is that the booster power wire? Or does power go through the coax?
  • Normally the 12v goes threw the coax, no need for separate wire. Did you turn on the power for the antenna amplifier? Red button next to the TV coax fitting, a red light should come on.
