SJ-Chris's avatar
SJ-Chris
Explorer II
Jul 22, 2021
Onan 4000 generator cranks but won't start
Hi all,
I have a 2015 Cummins Onan RV QG 4000 generator. It has somewhere between 300-1000hrs (not sure, I've only owned it for about 2 years and it was a previous rental...might not be the original generator on this RV and I don't trust the hour meter coming from the rental company). About 1 year ago, I replaced the oil, air filter, and spark plug. Since then there has been 50-100 hours. Up until recently it has been working fine.
Recently, it won't start. It cranks and cranks very strong, but doesn't start.
To troubleshoot so far here is what I have done to no avail...
- I have a full tank of gas in the motorhome.
- The motorhome is level.
- Altitude adjustment set to 0 (I am near sea level).
- I checked the oil to make sure there wasn't too much (it is to the low end on the dipstick as most seem to recommend).
- I swapped in a good spark plug to make sure that wasn't the problem, and it didn't fix it.
- I checked the air filter and it seems fine (...even tried starting it without the air filter and it didn't start).
- I changed the fuel filter with a new one, primed it and tried starting it several times and that didn't fix the problem.
- I disconnected all the batteries (and my solar) per someone's suggestion to "reset" the generator. Hooked everything back up and it still didn't fix the problem.
It still cranks very strong...just doesn't start.
The only error code I could get from the lights was '4' (which is over-cranking). I don't think in all the testing that I did I ever let it crank for more than 10-20 seconds at a time.
I have reached the current extent of my generator knowledge! lol.... I'm hoping some of you can help me expand that knowledge with some more suggestions/recommendations.
One thing I've learned about owning an RV (...I actually have 3 now) is that it makes sense to try to learn to fix as much yourself as possible because RV mechanics are a)busy, b)expensive, and c)a hassle to drop off/pick up/etc. Plus, it's fun/satisfying when we can fix our own rigs and not be as dependent on others.
Thanks in advance!
Chris
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Mar 02, 2026
