Kpackpackkelley
Jun 17, 2013Explorer II
Ky service manual
This may help. I would start by taking the gasoline solenoid off the carb at the bottom and clean it out. When you take it out there is a spring and pin in it . While you have it out apply 12 volts to it to make sure the pin pulls in that's what lets gasoline in the carb. I don't believe the spec k had a low oil pressure switch but check the parts manual on which spec had one. Good luck the others will be along shortly to help. Ps if you have a multimeter make sure you have 12.7 volts to your start solenoid and with start switch pushed you have 12.7 v coming out of start solenoid. No light on start switch sounds like low battery or bad connection at start solenoid.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
