ImaginaryNumber
Jun 19, 2013Explorer
Well, I verified spark and fuel flow, and even got it to run for a a short time but it appears to starve out a few seconds after the start switch is released. KpackKelly mentioned
"I would start by taking the gasoline solenoid off the carb at the bottom and clean it out. When you take it out there is a spring and pin in it . While you have it out apply 12 volts to it to make sure the pin pulls in that's what lets gasoline in the carb..."
How can I get the solenoid off with the carb on the genset and the genset in the Trail Lite compartment? I can't seem to get a wrench on the fuel solenoid because the carb bowl drain is in the way.
Thank you.
Thank you.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
