DAS26miles's avatar
DAS26miles
Explorer II
Jul 01, 2018
Onan 4K needs oil change, which oil brand and SAE
My Onan 4K is about to need the 150 hour oil change. Last service was thru an authorized service dealer and I know it was expensive. I used to use Pennzoil 30 in my Winnebago as I don't travel where the temperature drops below freezing. Can't seem to find it anywhere. The other oil recommended was 15-40 for temps down to 10?F. I did find some but it said it was designed for diesel engines. Would a regular motor oil of 10-40 work just as well or do I need to spend the bucks for the Onan brand?
Just found Shell Rotella T-4 SAE15w40, will that work? Probably not as it's for diesel engines and a syn blend, right?
Also found 10w40 available for gas engines but says for high mileage cars.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
