riggsp
May 15, 2016Explorer
Be sure to check the oil level in the generator...a stuck float, not allowing the needle valve to close, can fill the oil sump with gasoline...that may be where the white smoke is coming from...oil level too high and being pulled into the cylinder through the breather.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
